I Rebuild my shee half month ago And ride it for fifteen days now It run pretty strong but I feel my gear that engage real hard sometimes. I think is the shift star and the adjustment of that part is not good but I tried to adjust it and never get it real good like the manual says is there any for to do it right
Thanks!
The ball and rod that engage the pressure plate to release and the adjustment in the center of the clutch basket is all related to the arrow on the clutch arm and the case. The adjuster in the pressure plate is how you line the arrows up. ;) And the Clymer does a good job at describing the process of adjusting the shift shaft. It can be a little tricky, but take your time, and follow the instructions carefully...
