banshee top end rebuild with athena 370cc kit what jetting to run and needle location
kmaster9751
hey guys! went out on the shee today and unfortunatly blew up the top end at least i hope thats all thats wrong havent opened it up yet but i just did a bottom end job on it and put in a hot rods stock stroke crank so hopefully its still okay... anyways i wanna rebuild it with the 370cc Athena big bore kit and wanted some feedback on what jetting i should run
elevation: 1200
stock carbs with 260 mains stock pilot (i forget what size)
toomey t5 pipes
k&n pod filters
vforce4 reeds
i believe im running 0 degrees timing ill have to check my timing plate when i get into it but any info on what you guys think i should be running with the new top end would be greatly appreciated!!
