Need help to remove reservoir
on the stock pipe at the right side, i noticed some white residues. after i parked the Shee, i heard a hiss and then i saw some fluid dripping out of a hose directly onto the hot pipe. it was a hot day with more than 35° celsius and the engine cooling probably wasn't ideal that day. is this coolant and the hose is part of the reservoir tank?  i forgot it. the hose leads under the fuel tank and ends nearby the ignition coil.
