Banshee bog diagnosis
im not aware of any spring that gets stronger with time but i doubt that was the reason for removing springs. likely its a quick down and dirty test of the clutch system to see if heading in that direction is worth while or look else where. with big tires and alot of paddle and alot of traction i could see it bogging any mtr if the clutch locks to much
Been running the same clutch, tire, gearing combo for almost 5 years. Never had an issue before. Now it does it on two motors. Something doesn’t add up.
I'm sure you've checked it but I've had my carbs be out of synch by like a millimeter or 2 and would cause it to fall on its face off the line but once it got goin she ripped. this happened on the trip to the dunes they were synched before the trip then out of synch when we got there.
