3D printed parts for mock up
Anyone use 3d printed pistons or domes for mock up purposes?
I am getting ready to fianlly go through my spare engine and have cylinders that need a bore as well as what is "supposed" to be a 4mm crank.
Want to mock it up with plastic parts. set it to print a pair of pistons, the models I have set up to run are 6 hours for a high resolution print per pair.
Do not want to reinvent the wheel if someone else has already done this....
  • Like 1
You better have a very expensive 3D printer. I have printed many parts for mockup on aircraft structures but the tolerances are not tight enough for engine internals. I know there are high end printers that do but those are rare.
Why not just measure the crank and cylinders and figure out what you have?
^^This
Envoyé de mon SM-G965W en utilisant Tapatalk
Technology is cool, and i have a full machine shop, plus the printers at my disposal.
print oversize and machine to dimension if i have to.
kinda want to machine a printed sintered metal part anyway
Like Claude i am a bit of a geek when it comes to technology. Have a couple printers and lathe/mill/surface grinder/bandsaw at home, have $80k plus in printers and full machine shop at work. Why not? All it is going to cost me is tome and some nylon for the first couple runs.... i have 4 spools of it right now.
  • Like 1
Guess I don't understand the usefulness of mocking up engine internals. Unless you are trying to redesign something internally and need to check for interference.😯...are you planning on building your own parts ?
Cause THEN I could understand it. THAT would be fun. To have an engine to experiment with and try out new designs on.
18 hours ago, 97Screamer said:
double post,
i want to explore some ideas, probably won’t come to anything but it is nice to be able to explore the “what ifs”
and looking at what Claude does i am a hack.... i am a machinist that tinkers with engineering shit without any formal schooling.
so no pissing contest here.....
my stuff will be functional first, after it works i might make it pretty
If you are doing it for fun to learn new stuff, go for it, i will help you if i can.
Dont know about your 3d printer, but our is about +/- 1/64 (0.015"), precision wise, 3d printer are not accurate.
What printing material you will use??? Wich printer ya got??
My primary I built. 12"x12"x12" It looks like ass but works beautifully.
Lulzbot 18" for the other one.
I have access to another 5 that are larger than the ones I have at a local maker space I am a member of.... I might use one of those.
the ones at work are HUGE and stratasys.
ABS primarily for the stuff I am doing.
