OEM Banshee Cylinders
Looking to put together a new top end for my bike to hold me out while I piece together my ground-up 4 mil. I currently have a set of big bore drag ported jugs with stock carbs, and T5’s. I’m interested in sending some stock jugs to redline and getting their playport package along with a set of SLP pipes which I will reuse for the 4 mil. Being that I cannot find a good set of virgin cylinders locally, where can I find a genuine set online for a good price? I know a lot of the “genuine top end replacement cylinders” on eBay are Chinese copies and not as good quality so I need help finding which ones are worth using.
12 hours ago, registered user said:
theres usually some factory jugs on ebay. or check craigslist. the china jugs arent the best qaulity but if your porting them anyways, they would be fine. the main problem i seen with them is the sleeve didnt match well with the casting but if you port them it would all get matched up ,so none of that would be a big deal
Ah, so there’s usually no issues with the metal quality of the sleeve or water jackets?
for a cheap alternative they look fine to me. the main reason i wouldnt normally recomend using them is because they likely need the port windows and casting matched up better. this would cost extra on top of the cylinder price. at that point you might be able to find a decent set of factory jugs.  just call around and weigh your options
  • 1 month later...
  • 1 month later...
 Share
