Shock length to fit yfz 450 arms
JoeSA
 Share
^ This. Alba long travel arms are cheap and will be close to the shock length you're looking at (call for 17.5"). There is a lot more to shock setup then proper length though. You need to know about valving, spring rate, uncompressed and compressed length, otherwise there is a good chance you're just wasting your money.
4 hours ago, JoeSA said:
I already fitted the 450 arms and shocks. Will these ones fit or not? I am running 450 shocks at the moment but would like it if the front could lift a little.
Just because you afro rigged shit together, doesn't mean you made them work. YFZ450 a-arms will not work on a banshee frame. Stop being a dumbass and run the correct parts.
  • Like 1
 Share
