I picked up a set of Keihin pwk 28mm carbs for a good price locally. I did some searching can't seem to find what the float height should be set at. One post said 16mm to the line on the float, other one said 19mm only( I would assume to top of the float). No real help on Keihin's sight either.
35 to 39mm carbs are 16mm
pretty sure 28s are 19mm
Just put some gas line on the gas nozzle tube part and hold the carb in your hand, blow into the line, push the float up until it stops the air, it should stop when the float is parallel with the carb body or just a TAD before. That's how ive always done it along with others as well and its works fine.
