Yeah just replace the fibers and steels and install the new springs
Sent from my LGMS210 using Tapatalk
Thanks for the help man, appreciate it  :thanks:
My Powerline Performance 350 Dune port has a Driveline Dune Clutch in it.
Installing the motor today, but won't be able to ride it until next weekend.
Not sure what kind of power you're putting down, but FWIW, Cam at Redline is putting in one of his Redline Racing Clutches w/heavy duty springs in my +80rwhp Serval.
I asked him if I'd need a lockout for the Serval, and he said, "The Redline Racing clutch w/heavy springs will hold all the power of a Serval no problem, but it will have a heavy clutch pull. If you don't mind a heavy clutch pull, then you'll be good to go."
I run that exact same clutch set up, and it works great......tell them fuckers you want some stickers too.
Sent from my SM-S820L using Tapatalk
  • Like 1
