Banshee will not run after some work
Dflynn926
  • 3 weeks later...
On monday went out to the badlands in Attica. Tank started leaking... fuel went into the throttle cable on the right carb, seized the cable. ordered a tors elimination kit and found a used tank. I had pulled the tank brass fittings out, and when cleaning the hole, I thought i may have put in the new screw a hair to far... oops. Oh well I will epoxy it and use as a back up.
