I have some play in the steering stem [about 1/8 in.] You can move the handle bars forward & back. I bought a used steering stem clamp and am thinking if this is worn some it may be causing the extra play. Does the seal take away any of this play or is that just to keep dirt and water out?? Thanks.
Edited by Craig B
^^ yes. Replace the seals in the upper mount. Lots of grease
JD I didn't know the steering stem clamps get greased. Time for billet stem clamps with a grease fitting!
Just that split o ring area.
I forget that company who makes /used to make the Delrin clamps. Savage 420 runs one. Has a grease zirt.
Ima have to design one.
