Hey guys, just got done porting out my stock banshee (trail port with med boost ports) and i added some stuff and would like u guys to look it over and tell me if it looks good.aiming for a trail bike with some long straights. Have a short vid as well.
1) What type of aftermarket exhaust do you have?
Pro Circuit
2) What type of airfilter do you have?
6" K&N, 1 big
3)air box with snorkel but 5 1" wholes in back of lid and 6 1" wholes on front inside lid of snorkel
4) What is your elevation?
800-1000
5) What size pilot jets are you using?
30
6) What size main jets are you using?
320
7) What temperature is your Banshee jetted for?
??? Usually 70-90 here
8) Do you have a port job?
Did myself, trail port, med boost ports
9) What kind of carbs?
Stock
10) What size carb?
Stock
Also put v4's on her.
Will post a vid of it idling as soon as i fig how
Nope, i did all this to it and was woundering if jetting seemed correct to everyone else. Whatcha think Mikey?
Pics?
sent from yo mammy house.
You forgot temps and elevation.
Really, only you can tell if it's jetted right. Either with plug chop or read.
Ya i did, 800-1000 ft 70-90°
Im gonna do my first plug chop first chance i get
What durations did you use for your trail port?
This my sound stupid to u pro's but i have no idea. I did a lot of video watching and bought the bits and did a clean up on exuast widening it but not hiring and then i dropped the windows almost all the way down and drilled boost ports. I will post pics as soon as i fig out how...
I have no experience with those pipes, but sounds like you should be close.
Have been ridden this set up yet? If so, how did it feel?
Not yet, gonna try to do a plug chop today pr tom if i can get someone to watch my daughter for a bit. Still wont be able to test it fully till i haul it somewhere. Live in the city : /, i have an awesome garage though. Whole layout under my house : )
download your pictures to imgur.com or photobucket....  IMGUR.com FTMFW IMO.....
ideally your jetting should be close but with home porting its not likely we will be able to really pin point  you in a solid direction.. and especially if you went in porting blinded with no idea on port durations
I had an idea but as i researched, i wanted bottom end so i didnt want to change the duration at all as it would raise my powerband, is what i understood but i could be wrong. I did barely hit it to clean it up nice though
