got some new stock carbs and went to put them on and everything is good but the slide wont go all the way down, the needle barely goes down and i cant get them in, ANY ADVICE WILL HELP THANKS
Or sometimes... :Clue:
How the fuck do you still have 25 pilots in your carbs with CPI pipes??
And WTF is a Clamp-On K&N??
No1, do you have the right slide in the right carb? cut out to air box
No2, make sure your needle is going into the jet tube, sometimes they fit loose and its a trick to get em in.
