I have a 2003 banshee, i just took it apart for a rebuild, it only had roughly 100psi in each cylinder. the problem i am running into is they are stock pistons "64mm" or "2.51969inches" but when i measured the cylinder wall it is 2.5205 inches is that to big for stock pistons? do i need to bore?
It depends some call for .002 some .003 . You really need to use a bore guage . I take take the caliper set it up on piston skirt , set my bore guage in caliper and then check cylinder in a few spots . The bore guage will tell u if the clearance is within spec and if cylinder is egged. I have seen a lot of bores clearance well till u get just above ex port then all of a sudden bam .005-.006 I usually check a bore in 4-5 spots
alright thanks guys im gona take them to a local shop, an also if i get porting done and get a cool head with 21cc domes, can i still run my stock crank? i just dont wana put money into it then the crank bearings go out or the crank.
