Hi there guys i have a stock shee with pods and pipes i done a comp test other day and i have 110psi in each cylinder i am running 95 gas wich is about 92 to u guys our gas is ron in new zealand not pon. So my Q is if i mill 25tho off my head can i still use this gas and what cc domes would it be EQ to and will i need to rejet and weld crank for this mod.. Thanks in advance
Sent from my GT-S5360T using Tapatalk 2
#1 your down on compression might wanna re ring it while you have it apart and put s lil scratch on the cylinder so the new rings will seat.
#2 I've gone .030 on pump with a rechamber might wanna check squish clearance now and report back before you start milling
