Also, you mention you are looking at plates and stators. Be very leary of the stator and cast plate combos.
STAY AWAY FROM:
RM
Rick's
Rickey Stator
Electro Sport
Racetech (suit your self folks, mine didn't work and I had to fix the replacement as well)
While this may be a stator issue you might wanna try to replace your spark plug caps with new ones first. Bad caps can have it break up bad/cut out in the high rpms. The caps are not expensive. Some suggest cutting back a lil bit on the wire before installing new caps to get a good connection.
I've already cleaned carbs and changed plugs. New pipes aren't an option as I'm not made of money. I sold my dynoport 2:1 to get the stockers. So what do you mean by stay away from cast stator and plates?
Check plug caps/boots.
  • Like 1
Do not buy a plate that is cast aluminum. Make sure to get a Billit one. They are 20-30 bucks more, however they prevent catastrophes that are known to happen with the cheaper junk powder cast cheapos.
I modded my stock plate. The OEM stators are the best ones. Look online for a working used one. Make sure you seal the stator side engine cover with RTV even though it has a gasket. I've had problems in the past with water getting behind there. May have been the reason why I killed a stator last summer.
Not the cutting out. With my current setup will it improve performance? I'm not worried about cutting out I know my stator is taking a poop.
Did you ever check the plug caps/boots? It's more common for them to do what you're saying than a stator.
Can you answer my question about the advanced timing? If my bike is running fine. With stick pipes .40 bore and single foam filter with box and lid with holes in it. No snorkel will the advanced timing make it worth the cost?
