Joejr915 Posted January 9, 2015 Report Posted January 9, 2015 I have a set of cases trenches for a 10 mil and I'm want put a supercub topend on them. Will all I need to do is bore them and will I nred to bore them deeper any Quote
trickedcarbine Posted January 10, 2015 Report Posted January 10, 2015 Supercub stuff will definitely need the top case bored to take the bigger sleeve size. Quote
RadarRacing Posted January 15, 2015 Report Posted January 15, 2015 I did a set recently. No need to do the trench any deeper but the top case has to be done and it cant be just bored , it has to have quite a bit of hand or cnc work, not just a bore as the lower part next to the crank journals gets square. Honestly the builders that do it for $100 or 150 are giving you quite a good deal. Quote
