crank question
chris_sims1981
Regular rod length is 110mm center of eye to center of eye. By adding rods that are 5mm longer you take stress off the exhaust side of the bore and piston by having less angle. Doing so requires a piston with different wrist pin height so that the piston isn't an additional 5mm out of the bore.
