karab32 Posted May 6, 2014 Report Posted May 6, 2014 Hello, guys just wondering how do i adjust the new tapped air screw. I noticed that the one on my new banshee werent adjust the same way on the carburetors is it normal ? There is one more screwed than the other just wondering thank you Quote
oldskool Posted May 6, 2014 Report Posted May 6, 2014 I might be a little confused with your question, but the newly tapped threads with screw would be your idle screws. Give your cable some slack at handle bars, then use those screws to set your idle on each carb. Once you get desired idle, adjust cable. Quote
karab32 Posted May 7, 2014 Author Report Posted May 7, 2014 I mean that the tapped screw are not adjust the same way in the 2 carb So i want to know if its important that the screw in the carb have to be adjust exactly the same? In the 2 carb or if it doesnt matter ? Quote
hoppedupandcutdown Posted May 7, 2014 Report Posted May 7, 2014 It does not matter how many threads are showing on the outside of the carb, since you have to file that down to install them. As long as both carbs are in sync and idle the same. Quote
