lian Posted November 12, 2003 Report Posted November 12, 2003 how much will cool heads with really high comprsion raise the horse power to and when you raise it do you have to do anything to the banshee after and how can i diconect the tors without spending money thanks lian Quote
mcaf29 Posted November 12, 2003 Report Posted November 12, 2003 O.k. first I'm not an engine builde but I can give you an experience answer. If you go to the high compression domes so you're making above 160psi or so you'll have to go to race gas or race gas mix. All engines are different so use the minimum amount of race gas to prevent detonation. You'll gain a ton of low end power from high compression (think about the super high compression of 4 strokes). My shee had arm-ripping bottom end with 17 cc domes. I went to stock size 22's after rebuild and the difference was night and day. I ended up going to 19cc domes w/ 50/50 race/93 mix for that low end torquey feeling again. Just my $.02 Quote
