sheerider11 Posted February 20, 2014 Report Posted February 20, 2014 Will my asv off my banshee master bolt directly onto a yfz? Looking to upgrade te brakes Quote
sleeper06 Posted February 20, 2014 Report Posted February 20, 2014 Master not gonna make a huge diffrence but the dual piston calipers will for sure Quote
sheerider11 Posted February 20, 2014 Author Report Posted February 20, 2014 Oh I'm doing everything as long as I can swap the lever right over Quote
MLack Posted February 20, 2014 Report Posted February 20, 2014 I've been looking into this as well. ASV has different part numbers for both so.......IDK Quote
trickedcarbine Posted February 20, 2014 Report Posted February 20, 2014 Master not gonna make a huge diffrence but the dual piston calipers will for sureI definitely think the Master it self makes a difference. It is way more progressive and allows you to ease in to the brake a lot more. It's not so much of that all or nothing feeling the stock banshee stuff makes. Quote
sheerider11 Posted February 21, 2014 Author Report Posted February 21, 2014 I definitely think the Master it self makes a difference. It is way more progressive and allows you to ease in to the brake a lot more. It's not so much of that all or nothing feeling the stock banshee stuff makes.Oh nice. And I thought that was just from my braided brake lines. But I do want the system from top to bottom. Some one has to know Quote
do-work-son Posted February 21, 2014 Report Posted February 21, 2014 Yep it will fit pink is yfz and blue is banshee Quote
hp2000 Posted February 21, 2014 Report Posted February 21, 2014 What year YFZ ? The 07 master is different than all the other banshee ones. Also the 07 YFZ is the one that punches more fluid. Sent from my iPhone using Tapatalk Quote
do-work-son Posted February 21, 2014 Report Posted February 21, 2014 05 didn't know that they changed master .. Is there any way to tell what year master ya have ? Quote
hp2000 Posted February 21, 2014 Report Posted February 21, 2014 O7 YFZ master with 07 YFZ asv Banshee asv knuckle comparison to 07 YFZ Sent from my iPhone using Tapatalk Quote
Abe Posted February 21, 2014 Report Posted February 21, 2014 So is the earlier model yfz master cylinder even an upgrade versus the banshee or the same ? Quote
hp2000 Posted February 21, 2014 Report Posted February 21, 2014 I did mine a while back so I can't remember clearly but I think 06 and under yfz450 MC are the same as banshees and only 07+ push more fluid. Sent from my iPhone using Tapatalk Quote
Abe Posted February 21, 2014 Report Posted February 21, 2014 Sweet. nice to know since I already bought two old style ones for both my rides. Fml Quote
uman1030 Posted February 21, 2014 Report Posted February 21, 2014 Yep 2007 is when the introduced the revised master cylinder which pumps more pressure. I did the same thing, ordered one then found this out moments later. Sent the seller a message to cancel the sale that I was looking for the 2007 higher pressure version. His reply was, this will still fit and he shipped the item. I will be sending mine back. Quote
Strm Trpr Posted February 21, 2014 Report Posted February 21, 2014 Man, you guys had me freaking out. I bought a complete YFZ450R MC w/Lever and had to check my eBay purchase history. Thankfully it's off a 2008. I also have the calipers, but they're off a 06, but those haven't been revised, so I'm all good... Quote
