wayne_smith97 Posted February 4, 2014 Author Report Posted February 4, 2014 What's your elevation? But regardless, both sides are way to far off I agree more than ten percent. And about 500ft asl Quote
04zSpittinKlotz Posted February 4, 2014 Report Posted February 4, 2014 One side is fucking dead. It'll never run right. Pull the top end bore it get new shit and start over thank you sheerider!!!! by the 3rd page nobody noticed that from his first post!!! i was about to check you fools! Quote
wayne_smith97 Posted February 4, 2014 Author Report Posted February 4, 2014 thank you sheerider!!!! by the 3rd page nobody noticed that from his first post!!! i was about to check you fools! Alright I will jerk it apart this weekend and start ordering shit I guess. Quote
oldskool Posted February 5, 2014 Report Posted February 5, 2014 The suggestions about a thought to be fuel issue was based on a running bike before tors removal. Quote
wayne_smith97 Posted February 5, 2014 Author Report Posted February 5, 2014 The suggestions about a thought to be fuel issue was based on a running bike before tors removal.Bike was running. The compression has been the same since I traded for it and it used to fire up with one or two kicks. Started acting up like same issue I'm having now so I tore the carbs down rebuilt them new jets gaskets etc. put a tors removal in and it's still doing the same thing. Took carbs back down and double checked all is good. I know the top end is due to be redone. So I will do the top end and if I still have issues I guess we will go from there Also new stator Cdi box coil. All that was replaced because of a firing issue in the past Quote
wayne_smith97 Posted March 15, 2014 Author Report Posted March 15, 2014 Found out today the Cdi box was bad. Just got it too! Carried over to bhatch21's house and hooked it up to his and no fire. Hooked his back up and it fired right back up. Quote
