chads300 Posted December 22, 2013 Report Posted December 22, 2013 Just got another banshee. The bike has CPI inframes um nerf bars extended a arams kn filter. Bike will start second kick when cold but it will not rev up at all. And the left cylinder pops and that's all that happens. Has tors eliminator kit also. Any help is appreciated Quote
hoppedupandcutdown Posted December 22, 2013 Report Posted December 22, 2013 What year? Still have parking brake wires hooked up? Quote
chads300 Posted December 22, 2013 Author Report Posted December 22, 2013 2006 cross tube is on. And I have a slight update I took to plug caps off and it will hit on both cylinders at higher rooms and it still has a pop to it with a flame. Tried moving it and soon as you start letting the clutch out it falls on its face Quote
troyzstang Posted December 22, 2013 Report Posted December 22, 2013 What year? Still have parking brake wires hooked up? ^^^^ Have to agree with Hopped up. had the same issue before Good luck Troy Quote
chads300 Posted December 22, 2013 Author Report Posted December 22, 2013 It has all that eliminated Quote
Starwriter Posted December 22, 2013 Report Posted December 22, 2013 1st things to do to any new to you bike. Compression test, leakdown test, new plugs, clean carbs and filters. If that doesn't make it run right, move on to check plug cap resistance, pickup coil gap, reeds, etc. There are also the user created problems. Carb bowls swapped, slides swapped, missing choke tube. Quote
hoppedupandcutdown Posted December 22, 2013 Report Posted December 22, 2013 start by switching your plug wires and see if the right side pops instead, that will test your wires and caps. Quote
chads300 Posted December 22, 2013 Author Report Posted December 22, 2013 Switched wires and the pop didn't change cylinders if anyone would want to see a video I could send it to there cell Quote
uman1030 Posted December 23, 2013 Report Posted December 23, 2013 Brothers bike had similar symptom and parking brake was removed. after banging our heads for a while trying about everything we were sure it was electrical and we ended up cutting the parking brake wire right by cdi and it cured it. apparently it was grounding some where on the chassis. if i recall it was a green/white stripe wire but i could be mistaken its been a while. Quote
chads300 Posted December 23, 2013 Author Report Posted December 23, 2013 Can anyone post a pic of this Quote
wayne_smith97 Posted December 23, 2013 Report Posted December 23, 2013 There will be five wires coming out of the Cdi box find the green and white one and make sure it's not grounding out on the frame or anything metal Quote
Zillaguy Posted December 23, 2013 Report Posted December 23, 2013 I had a similar problem and it was a plugged pilot jet in the carb.... Quote
03DMshee Posted December 23, 2013 Report Posted December 23, 2013 I think my brake wire was green and yellow...but mine is 03 so.... Quote
