AintNoGoat Posted November 7, 2013 Report Posted November 7, 2013 I just bought my banshee, I took it too the flats and I couldn't seem to get in 5th or 6th gear. When I hit 5th gear the engine just completely bogged down on me and lost all power until I down shifted into 4th gear. I couldn't even do a wheelie with the thing. Could it be the jetting or something? I don't know at all what the jetting is on the thing. Banshee Mods: 2001 Banshee Stock Cylinders Bored to 28mm or 30mm V Force 3 Reeds Carbon Fiber Tyson Racing Motor Triple Drag Ported CPI Inframe Drag Pipes with Cascade Silencers K&N Air Filter Quote
03DMshee Posted November 7, 2013 Report Posted November 7, 2013 Bike runs completely fine in first 4 gears? And 28-30mm sounds like your possible carb sizes...cyls will be in 60's mm range Quote
AintNoGoat Posted November 8, 2013 Author Report Posted November 8, 2013 Bike runs completely fine in first 4 gears? And 28-30mm sounds like your possible carb sizes...cyls will be in 60's mm range Yes it runs fine 1-4 I believe Quote
Surfrjag Posted November 8, 2013 Report Posted November 8, 2013 Find out what jets are in it and check/replace plugs Quote
Larry's Shee Posted November 9, 2013 Report Posted November 9, 2013 Comepletly clean the carbs, set float level, check flow from tank valve. Sounds like it could be running out of fuel, maybe tank vent? Fuel valve? I prefer to soak them, not just a douche with spray. Quote
