DB87 Posted July 20, 2013 Report Posted July 20, 2013 Hey guys I wanna run a LED light bar on my stock banshee. How do I do it? I have stock stator. The link below is for the light bar I wanna run. Thanks guys. The BansheeHQ community is awesome. http://www.RigidIndustries.com/10-E-Series-LED-Light-Bar-p/e-series-10.htm Quote
5150banshee Posted July 20, 2013 Report Posted July 20, 2013 Talk to hp2000 he may charge u for the info tho lol jk he made a custom removable bracket for his banshee. Slaps it on at night. Sent using Tapatalk Quote
Starwriter Posted July 20, 2013 Report Posted July 20, 2013 You need to do a DC conversion. Float the ground on the stator and wire up a rectifier/regulator. Although you don't have to put in a battery, as long as you're changing the wiring, you might as well put one in. That way, even if you shut off the motor, you still have lights. https://www.google.com/search?num=100&safe=off&site=&source=hp&q=dc+conversion+site%3Abansheehq.com&oq=dc&gs_l=hp.1.0.35i39j0i20l2j0l7.3249.4585.0.8059.2.2.0.0.0.0.179.307.0j2.2.0....0...1c.1.21.hp.zM5J1z96iQA Quote
FullThrottle_06' Posted July 21, 2013 Report Posted July 21, 2013 Race Tech DC conversion. Problem solved Quote
So Cal Suspension Posted July 21, 2013 Report Posted July 21, 2013 You need to do a DC conversion. Float the ground on the stator and wire up a rectifier/regulator. Although you don't have to put in a battery, as long as you're changing the wiring, you might as well put one in. That way, even if you shut off the motor, you still have lights. https://www.google.com/search?num=100&safe=off&site=&source=hp&q=dc+conversion+site%3Abansheehq.com&oq=dc&gs_l=hp.1.0.35i39j0i20l2j0l7.3249.4585.0.8059.2.2.0.0.0.0.179.307.0j2.2.0....0...1c.1.21.hp.zM5J1z96iQA That, and those rigid bars flicker like crazy without a battery at lower RPMs. Especially after doing the DC conversion, because you actually lose wattage. Quote
So Cal Suspension Posted July 21, 2013 Report Posted July 21, 2013 Fuck baja designs buy rigid! hmmmm, no. Baja designs is in every way superior to rigid, but you pay for it... lol Quote
rubberneck Posted July 21, 2013 Report Posted July 21, 2013 The funny part is you dont pay any more really. A 10inch E series rigid is about the same price as an 8 inch OnX by BD. Put them side by side and see which one puts out more light. On top of that the end user can change the optics on a BD light. I can change mine from spot to flood to driving in minutes. Cant do that with a rigid or any other brand. Soooo lets see smaller light, more light, more versatile and really the same cost. Hmmm which one do you want. Yeah you're right fuck BD go ahead and buy that rigid. Not to mention BD has the best customer service of about any company ive ever worked with. Cant say the same for my interaction with rigid. Quote
