turbowrenchhead Posted June 18, 2013 Report Posted June 18, 2013 So I just found that my rear bracket is bent and is the cause of throwing my chain. Will a 91-06 rear collar fit up on my 87 axle? Quote
turbowrenchhead Posted June 18, 2013 Author Report Posted June 18, 2013 89-06 is the same 5 spoke design right? 87-88 is a 4 spoke? Quote
Dick Dragon Posted June 18, 2013 Report Posted June 18, 2013 I believe they are the same. When I ordered my axle it listed "all years" for application. Quote
Starwriter Posted June 18, 2013 Report Posted June 18, 2013 The later style is actually 6 bolt. It is a little bigger in diameter. The later style swingarms have the rectangle tubes flattened out at the back end. Possibly for clearance of the bigger sprocket hub. So, what I am saying is that the larger diameter sprocket hub may hit the swingarm tube on the early style swingarm. I have both styles but have never tried to swap hubs. Quote
toytech Posted June 18, 2013 Report Posted June 18, 2013 I had a 87 sprocket hub on a 2000 swingarm and carrier. worked perfect Quote
