Derrickc14 Posted June 8, 2013 Report Posted June 8, 2013 Im cleaning and tuning my carbs and throttle cables right now and I have both dimples show up ar the carb windows at full throttle +! . Both cables are synced and opening at the same time +! , but my right carb looks more open then my left carb - :/.? I snap the throttle and hold the left carb from snapping down so I can hear if the right carb is bottoming out. Which it does. Is that normal for the right carb to be oppen more then the one on the left with the choke?? Quote
hoppedupandcutdown Posted June 8, 2013 Report Posted June 8, 2013 They should be the same,make sure your cables are laying without any twist or binding. Quote
Derrickc14 Posted June 11, 2013 Author Report Posted June 11, 2013 idle screw lol. After i made this I relized im a dumb ass and grabbed a screw driver and adjusted it down. then i turned each one till the needle just started to barley move. Then 2 turns out to start with. I think im going to grab the guage that reads the pressure/vacuum to get it perfect. Im anal as shit and like my stuff to be perfect. thanks guys! im really sorry for waisting your time. Derrick...... p/s i just did my pivot swing arm bearings and holy shit, what a bitch. every six months im pulling that bolt out and lubing it. If it seizes on me again ill burn the shee to the ground lol. Quote
