installed a set of brand new toomey t5s a few days ago and had it jetted nice and everything and it was working awesome and pullin hard, but today it was workin like crap from the second i had started it. it has trouble opening up unless i clutch it and in 5th and sixth gear i cant get it to open up at all. today was raining and pretty damp if that might make a difference. tried new plugs even though it was running on two cylinders. stock except for t5s, uni filter and no air box lid. never checked compression yet but was working 100% when i parked it.
checked all over the pipes looking to see if the harness would be touching the pipes and never noticed where any wires were too close to the pipes. where would this most commonly happen, up on the stingers? or some where on the mid pipe? im almost certain that this is the problem because of the way it was missing
You posted that you have the stock airbox. There are 3 tabs on the right side of the airbox to hold the wires away from the right stinger. The wire harness goes over, under, over the tabs, or something like that. This problem is more common when people run pods and don't do anything to tie up the wires.
 Share
