Jpan350 Posted May 18, 2013 Report Posted May 18, 2013 I just traded for a banshee so I'm new, but the night I traded it started and ran perfect. The next day I go to start it and the right sides smokes and the left doesn't and the powerbands will not kick in plus when you shift into fifth and sixth gears it stops pulling. Quote
Surfrjag Posted May 18, 2013 Report Posted May 18, 2013 sounds like you got a problem.. we need more details and you may do a little research so you can ask a more specific question Quote
bansheegoon Posted May 18, 2013 Report Posted May 18, 2013 The yellow power bands work awesome or the red ones Quote
joey83 Posted May 18, 2013 Report Posted May 18, 2013 Need new power bands man!X2But before you just jump in and spend $45+ ea on a powerband, check the tension on yours. Quote
joey83 Posted May 18, 2013 Report Posted May 18, 2013 But maybe back up even more. If it's only running on one cylinder try a set of plugs. see if both sides have spark. Maybe check compression on each cylinder. Do something. Fuel, fire, compression, and in the right timed sequence will make her run. Start checking stuff and eliminate possible problems and get more info. Quote
toytech Posted May 18, 2013 Report Posted May 18, 2013 I thought puple powerbands were the best? Quote
toytech Posted May 18, 2013 Report Posted May 18, 2013 purple I thought purple powerbands were the best? Quote
Jpan350 Posted May 18, 2013 Author Report Posted May 18, 2013 It had a blown head gasket and antifreeze in the left cylinder I tore it down last night... How do you check tension on the power bands by the way. 1 Quote
99michael Posted May 18, 2013 Report Posted May 18, 2013 It had a blown head gasket and antifreeze in the left cylinder I tore it down last night... How do you check tension on the power bands by the way. Hahahahahaaa,, You guys are funny shit,, Quote
bansheedemon Posted May 18, 2013 Report Posted May 18, 2013 ... How do you check tension on the power bands by the way. So……… is this a real question then? lmao. Might want to get a manual for it……… lol 1 Quote
joey83 Posted May 18, 2013 Report Posted May 18, 2013 Stock head or cool head? Lay a flat edge across it and make sure head is nice and level so youre not doing another head gskt in 3 hours. Get a torque wrench and get a manual on it. I cant remember what I have. Is it Clymers that has best manual? Quote
bansheegoon Posted May 18, 2013 Report Posted May 18, 2013 Start at 17ft lbs then 20ft LbS In The numbers sequence on the head. I take my cool head to 22ft lbs and use a picture of a stock head on Google search as my reference. Power bands are behind the radiator I think and you can check tension with your fingers ;P just play in power bands are set up by different porting and pipes Quote
