SpeedRacer88 Posted April 29, 2013 Report Posted April 29, 2013 I have a 1-5 dunable is the any way I can swap it to a 'pro mod'? I have a extra 6th gear and drum? Can I just install a cut 6th and stock drum? The engagement ears are back cut.... Will that hurt anything? Sent from my Galaxy S3 using Tapatalk 2 Quote
Redline Racing Posted April 29, 2013 Report Posted April 29, 2013 You will need a lot of the gears. Your sliders on your cntr shaft will be back cut. So there is two gears. One of Your 3/4 pinion's is split on your main shaft the other has at least 1/2 the dogs cut off. This is just a start. Either trade someone for a stocker and get it pro cut or trade for a pro cut. Quote
SuperMex Posted April 29, 2013 Report Posted April 29, 2013 I have a procut I might trade, pm me. Quote
