I have a 1-5 dunable is the any way I can swap it to a 'pro mod'?
I have a extra 6th gear and drum?
Can I just install a cut 6th and stock drum?
The engagement ears are back cut.... Will that hurt anything?
Sent from my Galaxy S3 using Tapatalk 2
You will need a lot of the gears. Your sliders on your cntr shaft will be back cut. So there is two gears. One of Your 3/4 pinion's is split on your main shaft the other has at least 1/2 the dogs cut off. This is just a start.
Either trade someone for a stocker and get it pro cut or trade for a pro cut.
