port job for the cylinders, cool head with domes, seal kit for the whole motor, pancake bearing, billet water pump and gear, top end gasket kit, clymers manual, new clutch, torque wrench, clutch holding tool, and a flywheel puller.
great post ^
You can also use a small impact gun to instead of buying a clutch holding tool but that can lead to stripping the threads if you get too carried away putting it back on.
It pays to go through the whole thing and buy a good $75-100 in OEM replacement hardware from Jeff at fast. All that stuff nickle and dimes ya', but at least it won't be the old $3.00 part that fucks ruins your $2000 motor.
Tusk makes a nut and bolt kit for about $30. That way when putting the bike back together, you have extra hardware.
I went with a stainless steel engine bolt kit when i stroked my engine and installed my over ride.
@jereme6655 thanks but how much should I get the cylinders bored and what size domes should I get?
@trickedcarbine and @rajuncajun I was thinking that but don't know where to order them from
Uhh, as said in my post FAST! You can just go through your motor on tear down and make a list of anything questionable. Then go on his site and make a list ahead of time with the names and part numbers out of his OEM section. Call him and spend dinero, wait for a box, open up said box, look in to said box like kid in Candy Land, begin rifling through said box, install great parts for a great deal to get great performance!
cal Jeff a t fast racing. he will stear you in the right direction and sell you the parts you need for your build.  get it ported or don't waist your money on a crank. been there done that, do it once do it right.
My bad I didn't know fast was the a website until I looked it up I'm just planning to get a lot of new parts for the motor anyways so far I came up with Modded shift star
Clutch pancake bearing
High flow billet water pump
Racing clutch kit
Allen bolt kit for both side covers
Straight cut gears
Cool head with domes
Advanced timing plate
Plus the 4mill stroker kit bore the cyclinders .30 over and get a hjr dune port and not sure if I should get the 2 into 1 carb kit
