reveal88 Posted March 17, 2013 Report Posted March 17, 2013 If I have a Hinson spring loaded basket with straight cut gears, with 59 on basket and 18 on Primary the the ratio is 3:28??? What gearing should I be with 421 cub, 39 Pwk carbs and inframe Shearers I'm at a 14-42 now. Found a deal on this setup need help Quote
Oregon dunner Posted March 19, 2013 Report Posted March 19, 2013 I don't have strait cuts on my ported 421 cub but i I have 13/44 and spin 22.11.8 10 paddle haulers. It's low geared for sure but I like the wheel spin when I get in to a steep tree shot with soft sand. Quote
m671054 Posted March 19, 2013 Report Posted March 19, 2013 I was only aware of spring loaded hinson in a 2.86 or 2.87 ratio cant remeber which. post actual pics of this setup. i dont think it exists. Quote
m671054 Posted March 19, 2013 Report Posted March 19, 2013 Googled it 2.81 on spring loaded 2.87 stock Quote
trickedcarbine Posted March 19, 2013 Report Posted March 19, 2013 That is definitely a 3.27/3.28 ratio. You sure you counted right? Quote
reveal88 Posted March 20, 2013 Author Report Posted March 20, 2013 Yes, the guy I'm buying it from counted each tooth Quote
n2otoofast4u Posted March 20, 2013 Report Posted March 20, 2013 At 59/18 the gears would even touch each other. Quote
trickedcarbine Posted March 21, 2013 Report Posted March 21, 2013 I dunno, I'm with N2O on this. You said he counted, but you should count. Quote
reveal88 Posted March 25, 2013 Author Report Posted March 25, 2013 I counted, the count is right Quote
trickedcarbine Posted March 25, 2013 Report Posted March 25, 2013 Ok, probably not a matched set then. Because that puts you at about 3.27-28 range and there is no way they would mesh. To be honest I've never heard of that ratio for these bikes, RZ's, or RD's. Quote
