10bender Posted March 12, 2013 Report Posted March 12, 2013 Ok I have a 2003 shee and I drove it into a deep puddle. It started to miss after that. I have cleaned all plugs and got it to run rite. It has started to do it agen and I have a buddy that's big on shee's and he has been helping me out. We are both stumped at this point. It's only running on the left cylinder we have cleaned the carbs 2 times and even put a different set of carbs on it does the same thing. Cleaned them also. We have pulled the wiring out of the quad and ohm'ed every connection to each one and it all looks good. I have taken the coil in and it checked out good. Even took my buddy's off of his running shee and still the same thing. Cdi out of his running shee and same problem. Swapped plug wires and stays in the right side. I ohm'ed the stator and it all checks out good. Even pulled the stator out of my buddy's and tryed it and the same problem. Even with his fly wheel and same problem. It has 105 pounds of compression in both cylinders. We are both mechanically inclined. Carbs are in sync. We have taken the motor out and are rebuilding it rite now. But I was thinking the piston was cracked. But it looks good. I'm scared that I'm going to rebuild this motor and its going to do the same thing. The only thing I can think of is crank seal or the crank has twisted. Am I crazy? Can anyone help me? Quote
Zillaguy Posted March 12, 2013 Report Posted March 12, 2013 How are your reeds? Broken, or chipped? Are you getting spark on the right cyl? The motor could have ingested water, hydro-locked the right cyl, and caused the crank to twist, water doesn't compress. Take it in and have the indexing checked, if it's off have it indexed and welded. Quote
10bender Posted March 12, 2013 Author Report Posted March 12, 2013 Reeds are in good shape... that's my next move to have the crank checked and welded. . I'm just tryimg to make sure I don't over look something important that I should have checked before the motor goes back together Quote
