SICRAPTOR Posted January 5, 2013 Report Posted January 5, 2013 Hey guys, just got front yfz calipers for my shee. I have an 89 but they won't fit. Can I swap spindles from a later year or do I have to change other parts too? Thanks Quote
bansheesandrider Posted January 6, 2013 Report Posted January 6, 2013 You need spindles from a 1990 or newer Banshee. The calipers are a direct fit on the spindles and the spindles are a direct fit on your bike. Quote
Finch Posted January 6, 2013 Report Posted January 6, 2013 thought there was something else you had to do even with newer spindles. Quote
Dahl87banshee Posted January 7, 2013 Report Posted January 7, 2013 Different hubs too I believe. Pretty sure the rotor is in a different spot Quote
bansheesandrider Posted January 7, 2013 Report Posted January 7, 2013 Different hubs too I believe. Pretty sure the rotor is in a different spot Negative, the hubs and rotors are the same for ALL years. Quote
SICRAPTOR Posted January 7, 2013 Author Report Posted January 7, 2013 Yeah just got em. U can just swap the spindles. Thanks guys Quote
Dahl87banshee Posted January 8, 2013 Report Posted January 8, 2013 Different hubs too I believe. Pretty sure the rotor is in a different spot Negative, the hubs and rotors are the same for ALL years. Thanks for the correction. Quote
