01bansheefox Posted November 20, 2012 Report Posted November 20, 2012 So im freshening up my new work area for the banshee and noticed im missing alot of tools, what are the tools needed to completely tear down and restore a shee and its engine? Specify which tools must be quality vs standard cost. Thanks! Quote
rjdgriff Posted November 20, 2012 Report Posted November 20, 2012 Metric wrenches/sockets and good Allen's, snap ring pliers, screw drivers pipe wrench can be helpful... That's the basics of what you need... Quote
01bansheefox Posted November 20, 2012 Author Report Posted November 20, 2012 I know the basic stuff i was looking more for banshee specific, dont i need a flywheel puller and a tool to compress rings so the piston fits into cylinders. I'm tired of paying someone to do the work, when i can easily do it myself. Quote
bansheefromhell Posted November 20, 2012 Report Posted November 20, 2012 you don't need a spring compressor, the bottom of the cylinder is tapered Quote
special06shee Posted November 20, 2012 Report Posted November 20, 2012 Yes.. The only "special" tool needed is a flywheel puller Quote
sheerider11 Posted November 20, 2012 Report Posted November 20, 2012 A flywheel puller, clymers, and a few basic tools. Quote
Starwriter Posted November 20, 2012 Report Posted November 20, 2012 Leakdown tester, compression tester, torque wrench, grinder for cutting worthless tabs off the frame, homemade 32mm (1 1/4")hex tool for removing lower steering stem bearing, low pressure tire gauge, Mothers aluminum polish. Quote
Starwriter Posted November 20, 2012 Report Posted November 20, 2012 oops, 30mm (1 1/8") hex tool for the lower steering stem bearing. Also need a 32mm (1 1/4") socket for the inner clutch hub nut. Quote
Dicklez Posted November 20, 2012 Report Posted November 20, 2012 just a swiss army knife will suffice. Quote
Surfrjag Posted November 20, 2012 Report Posted November 20, 2012 Flywheel /clutch holder tool is nice Quote
Finch Posted November 20, 2012 Report Posted November 20, 2012 big hammer. 24 and 32 mm socket impact screwdriver is nice too Quote
01bansheefox Posted November 20, 2012 Author Report Posted November 20, 2012 Clutch holder, is that the tool i see if i type in banshee clutch tool on ebay?? Quote
Starwriter Posted November 20, 2012 Report Posted November 20, 2012 impact screwdriver is nice too Oh yeah, gotta have an impact driver for those dumb ass phillips clutch and stator cover bolts. Quote
Surfrjag Posted November 20, 2012 Report Posted November 20, 2012 http://www.rockymountainatvmc.com/p/44/73/270/731/-/18289/Tusk-Clutch-Holding-Tool Quote
