Better throttle response and also supposed to give you a small amount more of power.......
Vf2 run good.....just gotta deal with making sure they don't let a screw loose into your motor
Vf3 was made to get rid of the screws however the air flow was a little worse than the vf2s
Vf4 have just been released and they are claimed to make the same flow numbers as the vf2s but without any screws....
they open farther as well, since the stock reed stops are removed, so it will need re jetted but they help lots, carbon fiber reeds are the best
wow, who are you? sure know soooo much in your 9 posts....... :Crybaby:
they do as mentioned earlier. change the throttel response. yes, vforce have been known to give a little bit more hp on the topend, but they are a top-end geared crisp reed, and not the end-all world of reeds. you basically pick a reed to suite your ridding style, needs, and budget. softer reeds will give you a more maliable and compliant low-mid throttle, which helps tonnes in more technical ridding. believe it or not, removing stock stops can hurt stock pedal performance. if you have new pedals, that's a different story.
