baxterl7333 Posted August 13, 2012 Report Posted August 13, 2012 If i found some good 421 cub cylinders, would they work with the banshee head? Would it be reliable? Or would they only be good with a cub motor? Quote
vulvafan537240 Posted August 13, 2012 Report Posted August 13, 2012 If i found some good 421 cub cylinders, would they work with the banshee head? yes Would it be reliable? yes Or would they only be good with a cub motor? cub cylinders is a cub motor. idk what the question is here. you will need a 4mm stroker crank for the 421 though. Quote
thomas h. Posted August 13, 2012 Report Posted August 13, 2012 Most all after market jugs bolt up to a stock tranny. I guess you will need a 4 mm crank to get the port timing correct. Since the head bolts don't change yes stock banshee head will fit but possible you would need a after market one to use 4 mill domes. Post some pics of your stuff Quote
