The name is Yamaha Frame Silver. It is the same for all years of silver frames and I have never found an off the shelf color by that name. You should be able to get touch up paint from Yamaha, if you are doing a complete paint you can use any silver paint. An automotive paint supply house should be able to come up with something that will match.
I believe it's close to the metallic aluminum stuff that Rust-o-leum makes. Just did my frame.... Thought it was close to stock.
You looking to do a touch up or a whole frame?
just some touch up, I want to avoid the rust.
Thanks, I'll try it.
JFI the color for the 04-06 frames is different from all the other years.
thanks!!
