sheerider11 Posted April 14, 2012 Report Posted April 14, 2012 When I sit in place and hold in the clutch my bike moves. If I keep gassing it if gets worse and worse till it basically grabs and takes off. But I smoked my clutch completely out to nothing trying to get this figured out. So i get a new clutch I want to avoid this happening. I don't have grooves in my basket, the rod and ball aren't welded, I'm lost. Quote
sheerider11 Posted April 14, 2012 Author Report Posted April 14, 2012 play with adjusting anything at all? Yeah. I'd back it all the way in on the perch and set it on the hub then would fine tune with the lever. Quote
Finch Posted April 14, 2012 Report Posted April 14, 2012 and still did it after messing with everything? Quote
sheerider11 Posted April 14, 2012 Author Report Posted April 14, 2012 and still did it after messing with everything? Yeah. I smoked the clutch up and never got it figured out. So when i get the new clutch i want to know what to do. It basically fades like the cable just stretches real fast Quote
sheerider11 Posted April 14, 2012 Author Report Posted April 14, 2012 clymers? That was no help. I'm gonna get a new cable and go with bel ray. I had type f but fuck that. I just don't get why it was starting to grab on its own. Pissin me off. Quote
Larry's Shee Posted April 14, 2012 Report Posted April 14, 2012 As with any vehicle, it's not good to sit there with the clutch disengaged for long periods. Check that the actuator arm and rod are not worn. Quote
sheerider11 Posted April 14, 2012 Author Report Posted April 14, 2012 As with any vehicle, it's not good to sit there with the clutch disengaged for long periods. Check that the actuator arm and rod are not worn. It would be like if I was starting for a race. Its not long at all. Quote
sheerider11 Posted April 14, 2012 Author Report Posted April 14, 2012 Any one else got any input? Quote
Larry's Shee Posted April 15, 2012 Report Posted April 15, 2012 And now the rest of the story. I ASS U ME d you were sitting at the top of a dune waiting for your buddy Consider getting pressure plate and inner hub checked for warpage, check bushing and sleeve in basket, check steels for warpage. Check rod and actuator arm as mentioned, might be worn enough that it isn't disengaging enough. Sorry no one else has any ideas Quote
sheerider11 Posted April 15, 2012 Author Report Posted April 15, 2012 And now the rest of the story. I ASS U ME d you were sitting at the top of a dune waiting for your buddy Consider getting pressure plate and inner hub checked for warpage, check bushing and sleeve in basket, check steels for warpage. Check rod and actuator arm as mentioned, might be worn enough that it isn't disengaging enough. Sorry no one else has any ideas That's what I'm gonna do just bite the bullet and start fresh. From the cable down. Quote
toytech Posted April 15, 2012 Report Posted April 15, 2012 we had to put a pressure plate in my buds shee cause it was warped and did the same thing. Quote
sheerider11 Posted April 16, 2012 Author Report Posted April 16, 2012 No shit, didn't think of that. Thanks for throwing that out there Quote
bikerjon Posted April 16, 2012 Report Posted April 16, 2012 we had to put a pressure plate in my buds shee cause it was warped and did the same thing. x2 warped plates will make it doo that too. Quote
