Finally did my first compression test on my shee i just got and my right side was 185 and the left was 167. dont know what the internals of the moto are (like dome size or port job or cylinder size). am i in trouble and i take it i need to run 110 fuel instead of 93. i ride at sea level +or-1000 ft. and what fuel to oil ratio should i be running. any advise would be helpfull thanks
whever the motor was broke in on is the safest bet......but 32:1 is usually the go to mix. Also your gonna need some 103-110 for that one.......if not your gonna spend a whole lot more money real quick....
yep... 18 psi diff is alot... pull it apart and see if a hone and a new set of rings will help it... and yes with anything over about 155 you want race fuel or at least AV fuel.
