vitos stock stroke cylinders 68mm bore, nikasil plated, stock length head studs, water jacket plugs. also have a set of 24cc pump gas domes and 68mm wsm pistons. setup was ran only for a few hours the pistons show signs wear on the intake bridges but are serviceable. <--- that is the 392 setup.
it could be turned into a 421 4mm by adding a different set of pistons and adding a spacer plate or cut 4mm domes.
$250 plus shipping
wow ida payed double to have those, yur a good dude that dont put cash first,yur the man!!!
