Buckwheat Posted December 18, 2011 Report Posted December 18, 2011 I want to build an engine. Our riding is exclusively medium to long distance grade (woods) riding. I would like to concentrate on mid to top end power. Fuel economy is a consideration due to the distance of some of our rides. I will also be installing a RZ 350 gear set. Should I stay stock with porting, or upgrade to different cylinders / pistons / crank / head? What is the difference between the cheetah and the wampus? Thanks, Wheat Quote
Redline Racing Posted December 18, 2011 Report Posted December 18, 2011 I want to build an engine. Our riding is exclusively medium to long distance grade (woods) riding. I would like to concentrate on mid to top end power. Fuel economy is a consideration due to the distance of some of our rides. I will also be installing a RZ 350 gear set. Should I stay stock with porting, or upgrade to different cylinders / pistons / crank / head? What is the difference between the cheetah and the wampus? Thanks, Wheat Depending on your size I would say a 4 mm stock cylinder or ported 350 mtr. With both these mtrs you could easily run stock carbs and retain great fuel economy. With a good parts package and mtr setup you will have great power. Quote
sheerider11 Posted December 18, 2011 Report Posted December 18, 2011 Depending on your size I would say a 4 mm stock cylinder or ported 350 mtr. With both these mtrs you could easily run stock carbs and retain great fuel economy. With a good parts package and mtr setup you will have great power. X2 on the 4 mm ported. Quote
Buckwheat Posted December 18, 2011 Author Report Posted December 18, 2011 I weigh about 185. Who does the best port work? Thanks for your help guys, Wheat Quote
BigRed350x Posted December 18, 2011 Report Posted December 18, 2011 I weigh about 185. Who does the best port work? Thanks for your help guys, Wheat Kevin @ HJR can port it for whatever you want to do. Great guy and top-notch work. You wouldn't be disappointed. - Jared Quote
Jereme6655 Posted December 19, 2011 Report Posted December 19, 2011 well if your talking the difference of a cheetah cub vs a wampus....there is no difference...in porting. They are the same port work cylinders......the difference is that the wampus IS a mono-block cylinder that is designed to LOOK stock. i will admit....if you either don't know banshees or if you know banshees but do not get down eye level with the motor....the odds of you being able to tell are slim to none. So the wampus is just a cheetah cub that looks like stock cylinders. More designed for street-racers. Quote
thomas h. Posted December 19, 2011 Report Posted December 19, 2011 X2 for Kevin Just tell him you goals and riding style FYI I have a four mill and I run out of gas way befor my brothers stocker Quote
Finch Posted December 19, 2011 Report Posted December 19, 2011 i do alot of trails im stock with cool head and +4 timing rode for 6 hours on a tank yesterday and plenty of power... Quote
Bkm2006 Posted December 20, 2011 Report Posted December 20, 2011 my motor in my sig has really good mid to top power.. just do a stoke stroke with an (aggressive dune port) .. everyone will tell you different sponsors to go with, so do what i did call around and check pricing and figure out who you like. never heard one bad thing about jeff at fast (built my motor) .... or kevin at hjr... and if you are thinking stoke stroke isnt going to be enough do the 4mill from the start, because once you port for stoke stroke you cant switch to 4mill... you will need new cylinders to port for 4 mill..... my 2 cents... Quote
camatv Posted December 21, 2011 Report Posted December 21, 2011 hmm depends on how the 350cc cyl is ported i have done a bunch of 4 mill's from previous ported 350's.. redlines dyno charts sure look impressive.. Quote
Wildcardracing Posted December 21, 2011 Report Posted December 21, 2011 A lot will depend on you budget for the build. If keeping decent fuel economy is a primary concern then a stock cylinder build is going to probably be the best option. A stroker crank will give you much broader useable torque curve if your budget will allow it. My recommendation is to call several builders and use the one you feel most comfortable with. Quote
