barahonapr Posted September 11, 2011 Report Posted September 11, 2011 Just wondering which intakes are better? Anyone know what brand FAST intakes are? And how are chariots? Any others let me know. Thanks guys Quote
jbooker82 Posted September 11, 2011 Report Posted September 11, 2011 (edited) A thick billit one with a built in cross over. It will move the carbs up and back so the LH carb bowl wont hit the clutch arm. Mine is a Boss Racing. White Knuckel also makes a good one. You can replace the intake boots for $15 when need bee. Edited September 11, 2011 by jbooker82 Quote
jbooker82 Posted September 11, 2011 Report Posted September 11, 2011 Matoon Machine http://cgi.ebay.com/ebaymotors/YAMAHA-BANSHEE-INTAKE-MANIFOLD-34-36MM-/320744283846?pt=Motors_ATV_Parts_Accessories&hash=item4aadd95ec6 I believe FAST's intake is a White Knuckle intake. It has the cross hairs in it. It is supose to keep air flowing straight thus increase the intake velocity. They also have a round hole so they would match up to V Force 3's much better. I would port or open up the plasic insert in VForce 3's so they were the same size as the intake's round opening. http://www.farmandsandtoys.com/partdetail.asp?partid=190 Quote
jbooker82 Posted September 11, 2011 Report Posted September 11, 2011 The square intake might better suit Vforce 2's. I run V Force 3's with cascade's reed stuffers / retainers. They allow you to remove the plastic insert and have a big square opening. http://67.199.65.66/cascade_innovations/newlook/store/store_View.cfm?STORE_AREA_ID=13&store_dept_id=83 Quote
papa_smurf49319 Posted September 12, 2011 Report Posted September 12, 2011 The square intake might better suit Vforce 2's. I run V Force 3's with cascade's reed stuffers / retainers. They allow you to remove the plastic insert and have a big square opening. http://67.199.65.66/cascade_innovations/newlook/store/store_View.cfm?STORE_AREA_ID=13&store_dept_id=83 Is there much of a gain to be had here? I run a boss billet 1 piece thats the circle to match up to my vforce 3's Quote
camatv Posted September 12, 2011 Report Posted September 12, 2011 any intake you can find that DOSENT have that stupid ass built in crossover bullshit. also intakes that use real mikuni carb boots instead of the cheap ass chinese knock off gurantee'd to crack out bullshit. i dont quite know why the junk costs more than the nice stuff.. i personally like the trinity intakes. yes i said trinity. no boost tube no cracked boots easy to port match to reeds built with nice alluminum and tilted corectly to clear the clutch arm most of the time.. also any other 2 piece intake works great as well UPP's are nice. and reasonable. there is a guy on sleeze bay out of arizona that has a nice timing plate and also sells intakes those look decent as well. Quote
Azryll Posted September 13, 2011 Report Posted September 13, 2011 I've had the Upp intakes without the boost hole. I havn't tried any others so I can't tell you if theres a power difference but Cam from Redline told me they work just as good others. They have been holding up well and I have no complaints plus I like that they are black. Quote
barahonapr Posted September 13, 2011 Author Report Posted September 13, 2011 So cam are u saying that the FAST ones or chariot ones aren't any good? Just wondering because I don't want to buy them then have them mess up in a couple rides ya know. Quote
jbooker82 Posted September 13, 2011 Report Posted September 13, 2011 (edited) any intake you can find that DOSENT have that stupid ass built in crossover bullshit. also intakes that use real mikuni carb boots instead of the cheap ass chinese knock off gurantee'd to crack out bullshit. What is wrong with a built in crossover. Mine has genuine Mikuni boots, and doesnt leak. I did yamabond it just in case. You can buy genuine mikuni boots from dennis kirk for 15 bucks or so. If any thing it acts as a girdle. I my banshee originally came with UPP intakes and 34mm PJ's and the carb had to be tilted so the clutch arm wouldn't hit the carb drain / plug. It looked like the perviouse owner bent the lever down and ground down the drain plug as well. Edited September 13, 2011 by jbooker82 Quote
Chariot Performance Posted September 13, 2011 Report Posted September 13, 2011 So cam are u saying that the FAST ones or chariot ones aren't any good? Just wondering because I don't want to buy them then have them mess up in a couple rides ya know. Our intakes can be used with or without the crossover plate unlike others available for sale. We use Mikuni boots and provide new gaskets and hardware. You do not need to use yamabond or anything under our boots. Quote
jbooker82 Posted September 14, 2011 Report Posted September 14, 2011 Our intakes can be used with or without the crossover plate unlike others available for sale. We use Mikuni boots and provide new gaskets and hardware. You do not need to use yamabond or anything under our boots. I could run mine with no cross over plate. Quote
barahonapr Posted September 17, 2011 Author Report Posted September 17, 2011 Alright so why is a building in crossover no good? Quote
jbooker82 Posted September 18, 2011 Report Posted September 18, 2011 Alright so why is a building in crossover no good? I am going to guess because some think they leak. I just sealed mine with yamabond. Quote
