tro Posted August 11, 2011 Report Posted August 11, 2011 hey guys. just got done putting in a new pivot bolt (worst thing in my entire life) and i decided to get some toomey t5's to put on it while it was sitting idle. finally got everything together today and i could not get it to start. had to roll start it down a hill and even then it really didnt want to run. when it does run tho the throttle seems like it sticks and it runs hot. did all of the jetting correctly and made sure the slides are on the right side and facing the right direction. and right now im kinda stumped. help please. Quote
Larry's Shee Posted August 11, 2011 Report Posted August 11, 2011 What jets you have now? What's rest of set-up? Quote
tro Posted August 11, 2011 Author Report Posted August 11, 2011 (edited) oh sorry about that. i got 280's and the clip is on the 4th groove on the needle. stock pilot, air screw 1.5 turns out. and boysen pro series reeds. stock reed housing. Edited August 11, 2011 by tro Quote
tro Posted August 11, 2011 Author Report Posted August 11, 2011 im at roughly 500 ft and toomey said the 280's are good through 2000 ft. would it be the idle screws on my TORS? really need some help. Quote
Larry's Shee Posted August 11, 2011 Report Posted August 11, 2011 Most pipes prefer 27.5 pilots. Might check for air leaks around reeds . Check through thread at top of page "What jets are you running" look for a set-up simular to yours. As to running hot you talking at idle or riding around? Quote
tro Posted August 11, 2011 Author Report Posted August 11, 2011 it wont idle at all. when i let it cool down and zip down the road the pipes get hotter alot faster then they used too. checked the plugs and its not running lean. if anything it looks like it might be too rich. and the toomey instructions said i can use stock pilot. im gonna go check for air leaks around the reeds. also i didnt put the stock brass reed stops in. was i supposed to? the boysen ones came with a thin brass strip that i thought replaced the olds one. Quote
tro Posted August 11, 2011 Author Report Posted August 11, 2011 just saw a setup like mine in that thread except he has his needle on the third groove. im gonna try that out and see what happens. Quote
tro Posted August 11, 2011 Author Report Posted August 11, 2011 def. was not the issue. i really dont know what can be wrong with it. maybe pilot? but i think it s bs that toomey says you can use stock pilot. Quote
Larry's Shee Posted August 12, 2011 Report Posted August 12, 2011 Try adjusting air screws in ? 1/8 - 1/4 turn at a time. Quote
tro Posted August 18, 2011 Author Report Posted August 18, 2011 found out the problem. the problem was i am a dumbass and forgot to put the vacuum tube back on that connects the carbs. but she runs great now. thanks for the help. Quote
