riding season has alredy started and i need quick advice ok 4mil long rod stock cylinder with mx port or 68mm wampus cylinder serval ported with stock stroke? either way i am gone spend around 1000 dollars i need new cylinders stock one are shot sleeve is cracked so either way i am buying new cylinders trinity told me a redy to run CPI 68mm wompus cylinder with serval port pc pipe and 20cc domes should give me right around 60-70hp with stock stroke they want 1350 for cylinder gaskets pistons head and domes. what would you guys recomend?
i was told the wompus would give a little mor midrange than the cub
The wompus comes in alot of different port layouts I believe. The serval cub will be more duner friendly than a cheetah cub.
well what would be better a serval stock stroke or a 4mil stock cyl mx ported
