Good to know he knows what hes doing, after I finish my build and break it in i'm gunna take it to him for a dyno session. And I was also wondering about your cool head, i'm going to be running 19cc domes I was told I need to run a 50/50 mix of race and premium gas. Is this true or would it be better to run pure race gas i'm in Michigan and unsure of my elevation.
imo... bring it straight to the dyno, the air fuel meter will let you know your jetting right off, no point in chancing a (lean) burn down right outta the gate.
with 19cc domes on a stk (64-65.50) bore(s) in michigan, with fresh topend should be into race gas compression 165/170psi or so and up.
Soon as everything gets bolted in the frame you'll be the first to get the call. Should only be a few more months till I finish cant wait to see what kind of numbers kevins dune port will pull.
