sand-paddles Posted March 19, 2011 Report Posted March 19, 2011 I just rebuilt my banshee this week because I had low compression. After putting it all back together I compression tested it and both cylinders had 150 psi, but while it runs I have a lot more air exiting on one cylinder than the other. Is it possible that my exhause is plugged up? It also had this problem before the rebuild which is another reason I rebuilt the engine. Quote
Banshee Chad Posted March 19, 2011 Report Posted March 19, 2011 No expert on internals, but sound like a posibillity. What pipes u got? And any weird noises coming from motor? One side get hotter than the other? And have u repacked silencers if aftermarket? Quote
Surfrjag Posted March 19, 2011 Report Posted March 19, 2011 have you done a leakdown test? have you synced the carbs? < one of these is most likely your problem Quote
sand-paddles Posted March 19, 2011 Author Report Posted March 19, 2011 Right now the pipes are paul turners but next week I'm switching to toomey t5. I have not really adjusted the carbs yet because I don't know how. I also did a whole engine rebuild replacing all seals and gaskets Quote
Banshee Chad Posted March 19, 2011 Report Posted March 19, 2011 Check pipes for blockage, and adjust the carbs. Thats a big deal. Quote
Burt Reynolds Posted March 19, 2011 Report Posted March 19, 2011 Do you mean more smoke or more air pressure Quote
pr0blumz Posted March 19, 2011 Report Posted March 19, 2011 I agree, sounds like you need to sync the carbs. Quote
