I just rebuilt my banshee this week because I had low compression. After putting it all back together I compression tested it and both cylinders had 150 psi, but while it runs I have a lot more air exiting on one cylinder than the other. Is it possible that my exhause is plugged up? It also had this problem before the rebuild which is another reason I rebuilt the engine.
have you done a leakdown test? have you synced the carbs? < one of these is most likely your problem
Right now the pipes are paul turners but next week I'm switching to toomey t5. I have not really adjusted the carbs yet because I don't know how. I also did a whole engine rebuild replacing all seals and gaskets
