10 mill cub needs niksiled. ring broke. comes with cool head. domes need cleaned up. upp intakes vitos crank has slack in it. cases have chain wack tha drain plug i use teflone on tha bolt cause someone uses an impact to tightin it up.... all of it for 650 plus shippin
500 for set up, cylinders stud extenders , upp intakes 38-41 , v force reeds billit spacers, cool head with domes think one dome is messed up, and tha good piston.....tha other one broke a ring and i head tha when they renisile tha cylinders they can also fill in tha port work....
crank 100 has slack in one rod from what i have been told
and
